I pressed Ctrl + Capslock instead of Ctrl+Tab 4-5 times. Each time the font-size of the editor shrunk. I checked Settings -> Editor -> Font, but the problem was not from font-size, it's like a "zoom-out" thing. I tried sudo apt-get remove codeblocks and sudo apt-get install codeblocks but unfortunately it didn't reset the preferences. What can I do now?
Asked
Active
Viewed 2.1k times
smrdo_prdo
- 197
It's just a zoom out shortcut. I was able to solve the problem by holding Ctrl and scrolling with the mouse wheel. Ctrl + Scroll Up to Zoom Out and Ctrl + Scroll Down to Zoom In.
I know this is an old question, but the answers are incomplete.
To reset your editor font size to normal you can use:
Edit->Special commands->Zoom->Reset from the menu,
or you can bind a shortcut for that (you need to have the codeblocks-contribpackage installed):
Settings->Editor->Keyboard Shortcuts and set to what you want, mine is Ctrl+0 (zero) because that is a common shortcut for this.
smrdo_prdo
- 197
