More often than not, on booting to Kubuntu 12.04.01, I get a pop-up message "An application has crashed, now or in the past". I dismiss the message and everything seems fine. Occasionally when booting recently to Windows XP as administrator (though not as regular user) I have had an equally non-informative message "Your system has recovered from a serious error".
Should I be worried; if so, how do I find out which application and fix the problem?
WGCman
  • 347
The details of recent application crashes are stored in the file /var/log/apport.log.
That should give you information on what application has crashed recently.
After that, I would recommend reading How can I track a bug that caused a crash?
I would also search Launchpad for the application that you are seeing crash to determine if this may be a known bug.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
