I am working on a new Toshiba Satellite c855d, and this morning it had windows 7 on it. Wireless was working. When I booted Ubuntu, wireless was once again working.
I install 12.04 onto it, and now the wireless connection is no longer functioning. I'm not quite sure what to do, and I'm not terribly knowledgeable on the subject.
Thanks for any replies!
Edit 1: Outputs for first commenter's requests
*-network UNCLAIMED
description: Network controller
product: RTL8188CE 802.11b/g/n WiFi Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: ioport:3000(size=256) memory:f0200000-f0203fff
*-network
description: Ethernet interface
product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
physical id: 0
bus info: pci@0000:06:00.0
logical name: eth0
version: 05
serial: 00:26:6c:15:c8:4e
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.0.130 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:41 ioport:2000(size=256) memory:f0104000-f0104fff memory:f0100000-f0103fff
and
00:00.0 Host bridge: Advanced Micro Devices [AMD] Family 14h Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Device 9809
00:01.1 Audio device: Advanced Micro Devices [AMD] nee ATI Wrestler HDMI Audio [Radeon HD 6250/6310]
00:11.0 SATA controller: Advanced Micro Devices [AMD] Hudson SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:12.2 USB controller: Advanced Micro Devices [AMD] Hudson USB EHCI Controller (rev 11)
00:13.0 USB controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:13.2 USB controller: Advanced Micro Devices [AMD] Hudson USB EHCI Controller (rev 11)
00:14.0 SMBus: Advanced Micro Devices [AMD] Hudson SMBus Controller (rev 14)
00:14.2 Audio device: Advanced Micro Devices [AMD] Hudson Azalia Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] Hudson LPC Bridge (rev 11)
00:14.4 PCI bridge: Advanced Micro Devices [AMD] Hudson PCI Bridge (rev 40)
00:14.7 SD Host controller: Advanced Micro Devices [AMD] Hudson SD Flash Controller
00:15.0 PCI bridge: Advanced Micro Devices [AMD] Device 43a0
00:15.1 PCI bridge: Advanced Micro Devices [AMD] Device 43a1
00:16.0 USB controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:16.2 USB controller: Advanced Micro Devices [AMD] Hudson USB EHCI Controller (rev 11)
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 0 (rev 43)
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 6
00:18.6 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 5
00:18.7 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 7
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter (rev 01)
06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05)
does this help at all?
Edit 2, installing the drivers:
When I get to the point of compiling and installing the driver, I'm coming up with a lot of error messages. I will paste the output here:
norma@norma-Satellite-C855D:~$ cd rtl8192ce_*/
norma@norma-Satellite-C855D:~/rtl8192ce_linux_2.6.0006.0321.2011$ make clean
gcc: error: /lib/modules/3.2.0-34-generic-pae/build/include/linux/autoconf.h: No such file or directory
gcc: fatal error: no input files
compilation terminated.
make[1]: Entering directory `/home/norma/rtl8192ce_linux_2.6.0006.0321.2011/HAL/rtl8192'
rm -fr *.mod.c *.mod *.o .*.cmd *.ko *~
rm -fr .tmp_versions
rm -fr Modules.symvers
rm -fr Module.symvers
rm -fr Module.markers
rm -fr modules.order
rm -fr tags
make[2]: Entering directory `/'
make[2]: *** No rule to make target `clean'. Stop.
make[2]: Leaving directory `/'
make[1]: *** [clean] Error 2
make[1]: Leaving directory `/home/norma/rtl8192ce_linux_2.6.0006.0321.2011/HAL/rtl8192'
make: *** [clean] Error 2
make[1]: Entering directory `/usr/src/linux-headers-3.2.0-34-generic-pae'
scripts/Makefile.build:49: *** CFLAGS was changed in "/home/norma/rtl8192ce_linux_2.6.0006.0321.2011/HAL/rtl8192/Makefile". Fix it to use ccflags-y. Stop.
make[1]: *** [_module_/home/norma/rtl8192ce_linux_2.6.0006.0321.2011/HAL/rtl8192] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-3.2.0-34-generic-pae'
make: *** [all] Error 2
norma@norma-Satellite-C855D:~/rtl8192ce_linux_2.6.0006.0321.2011$ sudo make install
[sudo] password for norma:
file or directory
