I am trying to install tasksel in order to install LAMP but for some reason it always gives me this error:
E: Unable to locate package tasksel
root@TheShop:~# sudo apt-get install tasksel
Reading package lists... Done
Building dependency tree
root@TheShop:~#
Braiam
  • 69,112
first try to sudo apt-get update
after that, try to install it from Ubuntu software center
if you still have problem, post it by editing your questions
aziz joh
  • 123
Did you try aptitude instead of apt-get?
sudo aptitude update
sudo aptitude show tasksel
I always use aptitude, gives a lot of useful information. See also this thread on severfault
steabert
  • 1,816
I have been through the same problem.
The simple solution that worked for me is to set up software sources to download from "Main Server".
One way to get to the "software sources" window is as follows:
  • Start Ubuntu Software Centre
  • Go to the Edit menu
  • Select Software Sources
  • Change download from to the "Main Server"
  • Then write these commands one by one in terminal:
    sudo apt-get update
Thats it.
sudo aptitude install tasksel seems to work in natty
As a tip change install to search to check if package is available
Bruno Pereira
  • 74,715
robin0800
  • 1,092
