Ubuntu 10.04 installed from Windows 7 (Wubi filesystme), Now Ubuntu is not booting giving this error.
Target filesystem doesn't have /sbin/init.
No init fount. Try passing init= bootarg.
BusyBox v1.13.3 (Ubuntu 1:1.13.3-1ubuntu7) built in shell (ash)
Enter 'help' for a list of build in commands
(initramfs)
I looked at the suggestions here.That can't solved my problem because Ubuntu is installed from Windows and all the drive shows of Windows. How can I get this to boot?
Hunzai
I found the following instructions from here under the section "How can I access my Wubi install and repair my install if it won't boot?"
It worked for me with little changes as below:
  1. Boot using Ubuntu live USB/CD
  2. Go in System -> Administration -> "Disk Utility" (For 10.04, for other Ubuntu version somehow reach to "Disk Utility")
    Make sure your partitions where Wubi created the root.disk file is mounded. If not, you have to mount it with the "Mount Volume" button.
  3. You should see the root.disk here -
    /host/ubuntu/disks/root.disk
    (Note: In your case the name can be different for "host")
  4. Perform file system check on this file as below:
    sudo fsck /host/ubuntu/disks/root.disk
    It corrects the corruption using the above command
  5. Reboot the machine
  6. Enjoy your Ubuntu
papukaija
  • 2,425
