99
I am trying to clone an SD card which may contain a number of partitions, some of which Ubuntu cannot recognize. Generally, I want to clone the whole volume, not only some partition. So, I mount the SD card and see something like this in the Log viewer:
kernel: [  262.025221]  sdc: sdc1 sdc2
alex@u120432:~$ ls /dev/sdc*
/dev/sdc  /dev/sdc1  /dev/sdc2
Since I want to copy the whole disk, I execute:
dd if=/dev/sdc of=sdimage.img bs=4M
File sdimage.img, 7.9 GB (7,944,011,776 bytes) is created (SD card is 8 GB). Now I mount another SD card and execute:
dd if=sdimage.img of=/dev/sdc bs=4M
The problem is that the second dd command hangs on some stage, and never succeeds. After this, I cannot reboot or shut down computer, and I need just to switch power off.
Is this the correct approach? Maybe there is another way to clone an SD card?
OS: Ubuntu 12.04 (Precise Pangolin), 32 bit.
Alex F
  • 2,009
5 Answers5
100
Insert the original SD card and check the name of the device (usually mmcblkX or sdcX):
sudo fdisk -l
You might see:
Device         Boot   Start      End  Sectors  Size Id Type
/dev/mmcblk0p1 *       2048  2099199  2097152    1G  c W95 FAT32 (LBA)
/dev/mmcblk0p2      2099200 31116287 29017088 13.9G 83 Linux
In my case the SD card is /dev/mmcblk0 (the *p1 and *p2 are the partitions).
Now you have to unmount the device:
sudo umount /dev/mmcblk0
Now to create an image of the device:
sudo dd if=/dev/mmcblk0 of=~/sd-card-copy.img bs=1M status=progress
This will take a while.
Once it's finished, insert the empty SD card. If the device is different (USB or other type of SD card reader) verify its name and be sure to unmount it:
sudo fdisk -l
Write the image to the device:
sudo dd if=~/sd-card-copy.img of=/dev/mmcblk0 bs=1M status=progress
The write operation is much slower than before.
bigbell
  • 53
Alon Fleider
  • 1,001
48
You should not be using dd on mounted devices.
Unmount all the partitions first, then your command should work.
See other answers.
ubfan1
  • 19,049
18
I am using dd tool to clone usb sticks with multiple partitions, here is my command:
sudo dd if=/dev/sdb of=/dev/sdc bs=4096 conv=notrunc,noerror
notrunc - do not truncate the output file
noerror - continue after read errors
Additionally if you'd like to see the status of the above while dd is progressing:
sudo dd if=/dev/sdb of=/dev/sdc bs=4096 conv=notrunc,noerror status=progress
slm
  • 3,155
tommyk
  • 4,556
13
dd is fine, but I prefer cat /dev/sdc/ > ~/backup.iso If you want to put it on an SD card again, just run cat ~/backup.iso > /dev/sdc
Vreality
  • 1,209
  • 22
Here are the steps which worked for me on Ubuntu to restore the image file (~/raspberrypi2.img in my case) back to a new SD card (inspired heavily by Alon's reply above):
  1. Insert the micro SD card via the card reader.
  2. Open the Disks app.
  3. Quick format the whole card (not a specific partition).
  4. Close Disks.
  5. Open terminal and execute:
    sudo fdisk -l
Relevant output (which showed there were no partitions due to the quick format of the whole card):
Disk /dev/sdb: 7.4 GiB, 7948206080 bytes, 15523840 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x6957f2f2
sudo dd if=~/raspberrypi2.img of=/dev/sdb
This step takes a few good minutes (even on USB3). Make sure to not interrupt it by any operation which will invoke mounting (opening the Files or Disks apps).
Thanks for everyone's answers.
muru
  • 207,228
BoazC
  • 31
