I am trying to install my wifi using:
sudo apt-get install bcmwl-kernel-source
But I get this error:
unable to correct problems, you have held broken packages.
Any ideas?
I am using Lubuntu 12.10
Braiam
  • 69,112
harr
Sounds like you have a broken partial downloaded, try:
sudo apt-get clean
and then do the
sudo apt-get update && sudo apt-get upgrade
and try to install the package again.
fabricator4
  • 8,471
  • 37
  • 39
This probably happened because you have a hold on the package, that needs to be upgraded before installation of your desired package.
You can get a list of actual hold packages with:
dpkg --get-selections | grep hold
Then you can try to fix the problem you are facing with:
sudo apt-get install -f bcmwl-kernel-source
or
echo "package_name install" | dpkg --set-selections
NB: package_name obtained via dpkg --get-selections ... command above.
You can also try to fix the installation:
sudo apt-get --fix-broken --ignore-hold install bcmwl-kernel-source
Unless something else is wrong, that should allow you to install the package.
Braiam
  • 69,112
