I just installed Ubuntu on my Samsung series 3 laptop (NP305E7A-A02US) with an AMD A6-3420M with Radeon HD 6520g graphics, and I am trying to install the flgrx experimental driver. However, I can not find the experimental driver, and when I use the stable version of that driver, the top bar does not show and the Unity launcher does not show up. On top of that, when I try to install the AMD drivers from the AMD site, it gives me the error One or more tools required for installation cannot be found on the system. Install the required tools before installing the fglrx driver. Optionally, run the installer with the --force option to install without the tools. Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended. See /usr/share/ati/fglrx-install.log for more details. I checked the directory and sure enough, it said Supported adapter detected. Check if system has the tools required for installation. fglrx installation requires that the system have kernel headers. /lib/modules/3.5.0-20-generic/build/include/linux/version.h cannot be found on this system. One or more tools required for installation cannot be found on the system. Install the required tools before installing the fglrx driver. Optionally, run the installer with --force option to install without the tools. Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended. I have no idea what this is and I need to fix it, as I was accepted into the Steam for Linux beta, and they recommended this amd driver. Any help is greatly appreciated. Thanks so much!
The error indicates that you need to have the kernel headers. Try installing just the kernel headers:
sudo apt-get install linux-headers-generic
and repeat your previous installation steps. If you have a hybrid graphics system (AMD + Intel graphics), the following instructions were quite helpful:
How do I get AMD/Intel Hybrid Graphics drivers to work?
I had the same issues but I finally found a way to use AMD drivers while keeping the Unity launcher working.
First in the terminal update your kernel with
   sudo apt-get install linux-headers-3.5.0-17-generic
Next go to the AMD website and download the 12.11 Beta drivers
Download the drivers and place the drive file (.run file) on the desktop
In the terminal run the following:
cd /home/yourname/Desktop (Replace yourname w/ your Ubuntu login username)
Followed by
sudo sh amd-driver-installer-catalyst-12.11-beta11-x86.x86_64.run
The AMD driver/catalyst installer should open, follow the step by step and restart!
Your unity bar should work while you have the latest drivers! WOo!
Also - to remove the watermark (For AMD testing only) simply open the terminal and run
sudo gedit /etc/ati/signature
Then replace "Unsigned" with 9777c589791007f4aeef06c922ad54a2:ae59f5b9572136d99fdd36f0109d358fa643f2bd4a2644d9efbb4fe91a9f6590a145:f612f0b01f2565cd9bd834f8119b309bae11a1ed4a2661c49fdf3fad11986cc4f641f1ba1f2265909a8e34ff1699309bf211a7eb4d7662cd9f8e3faf14986d92f646f1bc
