96
I was wondering if anybody knew a command that would allow me to open a Nautilus (if that's the right name for the Ubuntu graphic/window explorer) window from the command line at the current directory that the user is at.
So, if I open a command line, and type:
cd /home/myUser/some/long/path/to/a/directory
Then, I'd like to be able to issue some command:
nautilus open-sesame
And have a graphic window opened to /home/myUser/some/long/path/to/a/directory. Is this even possible?
Jorge Castro
  • 73,717
zharvey
  • 1,795
6 Answers6
126
You can type in the terminal:
and then:
nautilus .
The above command will open nautilus in the folder /home/myUser/some/long/path/to/a/directory (the period is the current directory)
Or in the Terminal just type:
nautilus /home/myUser/some/long/path/to/a/directory
Fabby
  • 35,017
Roman Raguet
  • 9,613
20
In order to avoid nasty warnings in my terminal I use nohup. To have it detached from my terminal I'm adding & at the end of my command. I also use the -w flag to open in a new window.
nohup nautilus -w . &
Note that, nohup will create a file with warnings.
You can send that to /dev/null like this:
nohup nautilus -w . > /dev/null &
EDIT:
If you don't want to type all of this all everytime you want to open nautilus, you can make a function and place it in your .bashrc or into a file that is sourced when you open your console.
open() {
    nohup nautilus -w $1 > /dev/null 2>&1 &
You could then use :
$ open path/to/open/
I would prefer that over an alias as mentioned here since it allows you to specify the path to open in nautilus.
Julien B.
  • 311
16
You can also do gnome-open .. gnome-open is similar to open on Mac which tries to open the file using the best matching application. By default, gnome-open . on Ubuntu will open the current directory in Nautilus.
There is an open command in Ubuntu as well but it does not work in this case.
wsaleem
  • 333
15
You should use xdg-open . (or xdg-open <path>) which is way more generic.
To open nautilus from terminal.
nautilus .
To open nautilus in the background and still use the terminal.
nohup nautilus . > /dev/null 2>&1 &
You can also make that an alias.
alias open='nohup nautilus . > /dev/null 2>&1 &'
You can also add that alias to .bash_aliases, to have it persistent.
echo "alias open='nohup nautilus . > /dev/null 2>&1 &'" >> .bash_aliases
So now, after restarting the terminal, you can just type open.
I'm running Ubuntu 18.04.4 LTS and I also experienced problems with some of the popular solutions above. What is currently working for me is:
nautilus -w $(pwd)
This method does not require additional installs, creating files, error handling, etc, and so appears to be the simplest.
I hope it helps!
Kulfy
  • 18,154
Rob
  • 111
