I have successfully installed the ATI Catalyst drivers on a my ATI hybrid graphics system running on Ubuntu 12.10. I have verified that OpenCL and OpenGL work independently; however OpenCL-OpenGL interop is not functioning correctly. I've done some debugging, but am not sure where to go from here. Can anyone help?
Details:
My system is an HP Envy 6 running Ubuntu 12.10 (all updates applied) with a ATI hybrid graphics system composed of an Radeon 7600m and Intel HD3000. I installed the latest ATI Beta drivers (v. 12.11) following these instructions:
How do I get AMD/Intel Hybrid Graphics drivers to work?
Doing this I was able to get OpenGL and OpenCL operational. glxgears runs at ~1200 fps and all of the OpenCL-only samples in the AMD APP SDK function as expected. However, any OpenCL-OpenGL interop applications fail to launch with a X Error of failed request: BadMatch (invalid parameter attributes) error. All of the sample code previously worked under Ubuntu 12.04 with the package manager ATI drivers.
To get a little more debugging information, I ran LIBGL_DEBUG=verbose /opt/AMDAPP/samples/opencl/bin/x86_64/SimpleGL. This detects my discrete GPU, appears to select the right drivers, and detects that OpenCL-OpenGL interop is enabled:
$ LIBGL_DEBUG=verbose ./SimpleGL
ukiDynamicMajor: found major device number 250
ukiOpenDevice: node name is /dev/ati/card0
ukiOpenDevice: open result is 7, (OK)
ukiGetBusid returned 'PCI:1:0:0'
ukiOpenDevice: node name is /dev/ati/card1
ukiOpenDevice: UKI_ERR_NOT_ROOT
ukiOpenDevice: node name is /dev/ati/card15
ukiOpenByBusid: Searching for BusID PCI:1:0:0
ukiOpenByBusid: ukiOpenMinor returns 7
ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
Platform 0 : Advanced Micro Devices, Inc.
Platform found : Advanced Micro Devices, Inc.
Selected Platform Vendor : Advanced Micro Devices, Inc.
Device 0 : Turks Device ID is 0x1a16b40
Number of displays 1
libGL: AtiGetClientDriverName: 9.1.11 fglrx (screen 0)
libGL: OpenDriver: trying /usr/lib/fglrx/dri/fglrx_dri.so
ukiOpenDevice: open result is 10, (OK)
ukiOpenByBusid: ukiOpenMinor returns 10
glXCreateContextAttribsARB 0x7f4e05938280
Number of interoperable devices 1
Interop Device ID is 0x1a16b40
libGL: OpenDriver: trying /usr/lib/fglrx/dri/tls/i965_dri.so
libGL: OpenDriver: trying /usr/lib/fglrx/dri/i965_dri.so
libGL error: dlopen /usr/lib/fglrx/dri/i965_dri.so failed (/usr/lib/fglrx/dri/i965_dri.so: cannot open shared object file: No such file or directory)
libGL: OpenDriver: trying /usr/lib32/fglrx/dri/tls/i965_dri.so
libGL: OpenDriver: trying /usr/lib32/fglrx/dri/i965_dri.so
libGL error: dlopen /usr/lib32/fglrx/dri/i965_dri.so failed (/usr/lib32/fglrx/dri/i965_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: i965_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: i965
libGL: OpenDriver: trying /usr/lib/fglrx/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib/fglrx/dri/swrast_dri.so
libGL error: dlopen /usr/lib/fglrx/dri/swrast_dri.so failed (/usr/lib/fglrx/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL: OpenDriver: trying /usr/lib32/fglrx/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib32/fglrx/dri/swrast_dri.so
libGL error: dlopen /usr/lib32/fglrx/dri/swrast_dri.so failed (/usr/lib32/fglrx/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Major opcode of failed request: 155 (GLX)
Minor opcode of failed request: 5 (X_GLXMakeCurrent)
Serial number of failed request: 28
Current serial number in output stream: 28
I'm not sure where to go from here. This could either be a lingering issue with the known ATI Ubuntu 12.10 problems or something new. Anyone have any suggestions?
