I have Windows 7 and wanted to replace it with UbuntuĀ 12.04 (Precise Pangolin), but when I was booting and starting installation of Ubuntu I chose to replace Windows on my SSD, and it saw this problem:
"/dev/sda contains GPT signatures, indicating that it has a GPT table. However,it does not have a valid fake MS-DOS partition table, as it should. Perhaps it was corrupted-possibly by a program that doesn't understand GPT partition tables. Or perhaps you deleted the GPT table, and are now using an msdos partition table. Is this a GPT partition table?"
Even when I click yes or no, it does not move on it seem like a no responding situation. Do I need Boot-Repair to solve it?
Atladica
  • 1,377
You just need to re-make the partition table, a quick fix. Boot off the LiveCD and select "try Ubuntu". Next run Gparted and select Device -> create partition table.
You can select advanced options which will give a menu where you can select GPT (GUID partition table) if want, and if the drive is larger than 2TB then I would recommend that you do so.
After you have have written a new partition table, you can select "install" and everything should go smoothly.
fabricator4
  • 8,471
  • 37
  • 39
