Ubuntu 12.10 ships Weston and Wayland. What are the basic steps I need to take to make them usable? Trying to start Weston gives this and then drops back to the command prompt:
$ weston
Date: 2012-12-06 CET
[10:53:58.368] weston 0.95.0
               http://wayland.freedesktop.org/
               Bug reports to: https://bugs.freedesktop.org/enter_bug.cgi?product=weston
               Build:
[10:53:58.368] OS: Linux, 3.5.0-19-generic, #30-Ubuntu SMP Tue Nov 13 17:49:53 UTC 2012, i686
couldn't open /home/ingo/.config/weston.ini
[10:53:58.368] Loading module '/usr/lib/weston/x11-backend.so'
[10:53:58.370] initializing x11 backend
libEGL warning: unsupported platform Windows
libEGL warning: DRI2: failed to authenticate
libEGL warning: DRI2: failed to open swrast (search paths /usr/lib/fglrx/dri)
libGL error: failed to load driver: swrast
libGL error: Try again with LIBGL_DEBUG=verbose for more details.
[10:53:58.389] failed to choose config: 0
[10:53:58.389] failed to create compositor
PS: I know that they aren't ready for prime-time yet, anything basic like opening a terminal or hello-world type thing in Weston would be enough.
Grumbel
  • 4,879
There is a bug in mesa-9.0. Try using mesa-9.0.1 (you may have to build from git)
The problem solved itself in 13.04, weston starts now out of the box, no setup required. It will open up as a separate window in Xorg and provide a Terminal along with a basic window manager functionality.
Grumbel
  • 4,879
I'm guessing you don't have mesa, please not that prior to executing the following shell script do mention if you have the below mentioned dependencies
  1. drm
  2. proto
  3. macros
  4. libxcb
  5. presentproto
  6. dri3proto
  7. libxshmfence
  8. pixman
  9. cairo
I'm taking a wild guess you don't have mesa because your log mentions about DRI. Try doing the following:
export WLD=$HOME/install
export LD_LIBRARY_PATH=$WLD/lib
export PKG_CONFIG_PATH=$WLD/lib/pkgconfig/:$WLD/share/pkgconfig/
export PATH=$WLD/bin:$PATH
export ACLOCAL_PATH=$WLD/share/aclocal
export ACLOCAL="aclocal -I $ACLOCAL_PATH"
mkdir -p $ACLOCAL_PATH
git clone git://anongit.freedesktop.org/mesa/mesa
cd mesa
./autogen.sh --prefix=$WLD --enable-gles2 --disable-gallium-egl \
 --with-egl-platforms=x11,wayland,drm --enable-gbm --enable-shared-glapi \
 --with-gallium-drivers=r300,r600,swrast,nouveau \
 --disable-llvm-shared-libs # this may be a bug in the llvm package
sudo make && sudo make install
cd ..
