I tried to apply the recommendation of question:
Kernel Panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
After running that command: sudo mount --bind /dev /mnt/dev
I get this error message: mount: mount point /mnt/dev does not exist
fdisk -l returns
/dev/sda1
/dev/sda2
/dev/sda5
do I need to mount sda2 and sda5?
Edited after @psusi's comment:
/dev/sda1
is the boot file system
It seems that I need to mount sda2 or sda5. Here is what I tried: (I tried this on a virtual machine so the sda(s) are now vda(s) )
ubuntu@ubuntu:~$ sudo fdisk -l
Disk /dev/vda: 19.3 GB, 19327352832 bytes
16 heads, 63 sectors/track, 37449 cylinders
Units = cylinders of 1008 * 512 = 516096 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0008eece
   Device Boot      Start         End      Blocks   Id  System
/dev/vda1   *           3         496      248832   83  Linux
Partition 1 does not end on cylinder boundary.
/dev/vda2             498       37448    18622465    5  Extended
Partition 2 does not end on cylinder boundary.
/dev/vda5             498       37448    18622464   8e  Linux LVM
ubuntu@ubuntu:~$
ubuntu@ubuntu:~$
ubuntu@ubuntu:~$ sudo mount -t ext4 /dev/vda5 /mnt
mount: wrong fs type, bad option, bad superblock on /dev/vda5,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
ubuntu@ubuntu:~$ sudo mount -t ext2 /dev/vda5 /mnt
       dmesg | tail  or so
ubuntu@ubuntu:~$
Any info that can help me rescue that server would be greatly appreciated!
howaryoo
  • 103
It looks like /dev/vda5 is an LVM partition. Which work differently than block devices.
You might try this link:
http://linuxwave.blogspot.com/2007/11/mounting-lvm-disk-using-ubuntu-livecd.html
I haven't worked with LVM much, but that link looks promising.
MCR
  • 321
The error message is a consequence of a full /boot partition because of many kernel upgrades. One quick way to fix is to boot the system using the previous kernel version. (the SHIFT key brings up the grub menu during startup).
Once up and running the full /boot partition can be cleaned up for instance with:
http://ubuntugenius.wordpress.com/2011/01/08/ubuntu-cleanup-how-to-remove-all-unused-linux-kernel-headers-images-and-modules/
howaryoo
  • 103
