Couple of hours earlier I installed the drivers of a HP DeskJet 3000, which I found here: http://hplipopensource.com/.
Since that moment I cannot install anything from the Ubuntu Software Centre. It seems that my root password is wrong now. But I haven't changed it! I have no problem log in to my profile, using my ordinary, very first password I have set when I installed Ubuntu, but when I need to use it as a root password, it is simply does not work...
Any ideas how to fix the mess?
Thank you in advance!
Hristo
Ubuntu does not have a root password. What your being asked for in software center is your password. Check your caps lock, etc. and try again.
Failing that reset your password from the terminal with passwd
And if that doesn't work, run sudo ls from the terminal and see if your allowed to sudo.
coteyr
  • 18,724
