I am installing CMake in ubuntu, after did the last step "make install", This is the result:
-- Install configuration:""
CMake Error at cmake_install.cmake:36 (FILE):
 file cannot create directory: /user/local/doc/cmake-2.8. Maybe need
 administrative privileges.
make: ***[install] Error 1
does it mean it didn't install successfully?
Seth
  • 59,332
weixi
  • 341
Installation requires root privilages. So you have to use sudo make install Instead of make install
Tachyons
  • 17,455
You can install cmake under your home directory. To this end you simply need to run the bootstrap script as follows:
./bootstrap --prefix=$HOME
Then you do not need to use sudo command
anonymous2
  • 4,325
If you specify a path during make, then it will install to the specified directory. Then you must try with sudo to install to this particular directory as
sudo make install
If you don't select any prefix during make, then it will be installed in your current directory. In that case sudo is not required.
Do you have a specific requirement to run cmake version 2.8.9? Version 2.8.7 is available from the repositories and can be installed by running the command sudo apt-get install cmake
If you must compile a version yourself you will need to run the make install command as sudo make install as your application needs permissions to install itself into the filesystem.
To check for cmake files after compilation, run the command sudo updatedb and then locate cmake
Finally, run cmake from the command line, without any options, specified and you should get some output on using various command flags if the application compiled correctly.
Update: rolled up previous comments into this answer.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
