Today, I tried to install the Cisco AnyConnect VPN Client on my computer running Ubuntu 12.04 updatet earlier today. I followed the instructions on this webpage https://innsida.ntnu.no/wiki/-/wiki/English/Install+VPN, but after I had typed in my username and password, it failed to connect and my computer was no longer able to connect to the internet.
It finds my router with no problems and it pings my DNS server as normal, but it times out when I try to ping www.google.com for example.
I realize that more information is probably necessary for anyone to help me, but I don't know much about networking.
best regards
Rolf
  • 61
Cisco AnyConnect VPN Client makes changes to /etc/resolv.conf. Make sure that the program restored /etc/resolv.conf to its original state. /etc/resolv.conf should be a symbolic link to "../run/resolvconf/resolv.conf". If this is not the case then run
sudo dpkg-reconfigure resolvconf
jdthood
  • 12,625
I had the same problem. With Ubuntu 12.10 I had installed Cisco AnyConnect, then found that I had lost my internet connection. I uninstalled AnyConnect, then saw that I was still having DNS problems, which prevented me from accessing anything on the Internet. Based on jdthood's answer, I looked at the file /etc/resolv.conf and saw this:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.0.1
127 is a localhost or something, so that didn't look right. I commented out the last line and added this:
nameserver 8.8.8.8
8.8.8.8 is the ip address of Google's DNS server. That solved the problem instantly. I'm not sure it's a permanent fix (judging by the all-caps warning not to do what I did), but it holds after rebooting, and my internet works again.
My case:
Ubutu 14.04, installed vpn by
sudo apt-get install network-manager-openconnect-gnome
then change the /run/resolvconf/resolv.conf to
nameserver 8.8.8.8
Now I can connect to internet with CISCO vpn.
the problem is once you disconnect VPN and reconnect VPN, the nameserver is written back to 127.0.0.1. You have to manually change it back.
muru
  • 207,228
