Please help! I am pretty "newb" to linux and have no idea what to do. I got the message "your system must reboot to complete updates" (or similar). After rebooting I am greeted with a giant login screen and my 2nd monitor isn't showing anymore.
After logging in, I can only see a part of my desktop -- one giant folder icon. I can right click on the desktop but gives me no option to change resolution or anything.
Any help would be wonderful.
PS: I am able to get a terminal window open. Luckily that ONE folder had a terminal shortcut I had put there. So if this can help troubleshoot, please advise.
EDIT 2: This got me back to Unity working and a nice resolution and both monitors:
 apt-get purge nvidia-current
 rm /etc/X11/xorg.conf
 reboot now
Unfortunately, now I guess I don't have any HW accel for my graphics card? :(
aikeru
  • 706
I had a similar problem when I tried to remove my nVidia drivers.
You need to re-install ubuntu-desktop to get your normal screen back.
Refer here for complete information : How can I uninstall a nvidia driver completely ?
VedVals
  • 3,651
Epilogue: Since it all seems to be working now, I should share what I did. Probably not the best way, but since I'm a newb I just went with what I can find. :)
  1. Downloaded latest driver for 64bit / Linux from nVidia site
  2. Download and install linux-headers-3.5.0-19-generic
  3. Open terminal, change directory to where the .run from nvidia is downloaded
  4. In terminal chmod +x ... the nvidia .run file
  5. Reboot into recovery and login to recovery terminal
  6. Run this command so nVidia script can write to stuff sudo mount -o remount,rw /
  7. Run the nVidia script itself sudo sh ./NVIDIA-...
  8. Ignore the first "... script failed..." error. Select option to allow it to blacklist, mostly "yes", "agree", etc.
I think that's everything. I didn't think of this, but had I not had the shortcut on my desktop to get to terminal, I could have just rebooted into recovery mode to get the terminal and while googling found a hotkey to get there too (CTRL + ALT + F1?).
After this everything seems to be working. I used sudo nvidia-settings from terminal to rearrange the physical location of my monitors properly.
EDIT: This happened again after I updated my system...
I ran this command that I found here:
sudo apt-get install linux-headers-`uname -r`
...and then basically repeated the entire process.
aikeru
  • 706
You could also check out xrandr.
With no option gives you a list of available defaults.
Update with i.e.:
xrandr --output HDMI-0 --mode 1920x1080
Runium
  • 1,663
I am using Ubuntu under Oracle VirtualBox and same thing happened to me. Also I lost the mouse scroll abilites, etc.
What I did to fix the issue was re-installing the Guest Additions and all the functionality came back.
Uygar Y
  • 391
