This is my First time so please help
Steps I Followed :
  • Install windows 8 pro with media center On my asus k55vm, i7 ,8gb.
  • Windows boots fine and is in perfect condition.
  • Booted into Ubuntu live USB and installed ( it detected windows, installed alongside windows 8 with recommended setting )
  • Installed perfectly. Rebooted, but no option to select Ubuntu, just loads into windows 8 without any option, tried boot repair and no use.
Please Help , tried many tutorials to no use , heard about easybcd also , any help ?
koceeng
  • 145
This issue is to do with UEFI. In Windows 8 on the start screen, type in "msconfig" (without the quotes) and in the boot tab, see if Ubuntu is listed. If it is, select the entry by highlighting it and click on "Set as default". This should hopefully load the Ubuntu bootloader instead of Windows' boot menu allowing you you boot into Ubuntu.
Also, from the start screen type in "uefi" and in the settings option on the seach charm, click on "Advanced start up options", click on it. Scroll down to the bottom of the entry and under "Advanced start up", click Restart now. You should now have an option to change the boot order.
Hope this works!
Ben
I have been having the same problem for a week. I installed both operating systems on different partitions of the same disk. After several trials, I managed to boot on Linux and Windows 8. Here is what I found so far:
  • Windows 8 boots if 'SecureBoot' option is enabled in the hardware level. During startup, I press F12 on my toshiba laptop to set this.
  • Linux versions (Ubuntu/Mint) boot if 'SecureBoot' option is disabled.
To go to Windows 8, I enable SecureBoot and restart the laptop. To go to Linux, I disable SecureBoot and restart the laptop. Though it takes an extra step, this is the only way I could use both operating systems on the same PC.
Good luck!
Nachi
I guess you have configured Windows 8 as the default OS during ubuntu installation, and probably the boot loader doesn't stay on the screen for fair enough time.
As soon as you boot your system, keep repeatedly pressing Up or Down Arrows, that might bring the bootloader to screen if the trouble was with the timer.
Aditya
  • 13,616
Ish
I had same problem. I followed the instructions in this video and it works fine now. http://www.youtube.com/watch?v=PK7gWIkAY7s
Good luck
user68186
  • 37,461
Parham
