For a bug I need to check if a bug still occurs on upstream kernel 3.7rc7, and since the bug is related to fglrx I need to install a newer version as well that work with kernel 3.7. How do I do this step by step?
I got my answer by combining different posts on the ubuntuforums. This guide will use the 12.10 version of fglrx from the ati site. All these steps are done in a terminal. This guide assumes you have kernel 3.7rc7 installed by following the steps in https://wiki.ubuntu.com/KernelMainlineBuilds. It also assumes you're running Ubuntu 12.04, however the instructions for 12.10 are very similar.
Create temporary directory and go to this directory:
mkdir ~/temp cd ~/tempDownload the ati driver and the patch:
wget http://www2.ati.com/drivers/linux/amd-driver-installer-catalyst-12.10-x86.x86_64.zip wget http://catalyst.apocalypsus.net/files/arch-fglrx-3.7.patchExtract the zip and make the
.runfile executable:unzip amd-driver-installer-catalyst-12.10-x86.x86_64.zip chmod +x amd-driver-installer-catalyst-12.10-x86.x86_64.runExtract the
.runfile in the./srcdirectory:./amd-driver-installer-catalyst-12.10-x86.x86_64.run --extract ./srcGo to the
./srcdirectory and apply the patch:cd ./src patch -Np1 --verbose < ../arch-fglrx-3.7.patchNow build the deb packages for 12.04 (precise), these will go in the parent directory
./ati-installer.sh 9.002 --buildpkg Ubuntu/preciseGo to the parent directory and install the files
cd ../ sudo dpkg -i *.debIf you get an error about
version.hand that building the dkms modules failed, this is because the file version.h is misplaced in kernel 3.7rc7. To fix this doln -s /usr/src/linux-headers-3.7.0-030700rc7-generic/include/generated/uapi/linux/version.h /usr/src/linux-headers-3.7.0-030700rc7-generic/include/linux/version.hand remove and install fglrx again
sudo apt-get remove "fglrx*" sudo dpkg -i *.debBackup your xorg.conf and generate a new one
sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf.bak sudo aticonfig --initial -f
Reboot it and it should work!
- 9,559
