I am trying to setup an Ubuntu hosting server, currently just for development, and the server has two NICs, each sitting on a different network. eth0 is on 192.168.200.* and eth1 is on 192.168.101.* and each one has a static IP. eth0 is the public facing NIC card and eth1 is strictly for internal access to the server. I initially only setup eth0 and added the eth1 card when I needed it. eth0 was working find until I added eth1, now, can't get any connectivity on eth0 unless I pull eth1 out of the box. The configuration on each system is as follows:
auto eth0
iface eth0 inet static
      address 192.168.200.94
      netmask 255.255.255.0
      network 192.168.200.0
      broadcast 192.168.200.255
      gateway 192.168.200.253
auto eth1
iface eth1 inet static
      address 192.168.101.64
      network 192.168.101.0
      broadcast 192.168.101.255
      gateway 192.168.101.254
Again eth0 worked fine until I added eth1. I have seen this happen with Windows servers if you have a Default Gateway setup for both NICs, but I am not sure if this works the same on Ubuntu. My resolv.conf file looks like so:
nameserver 192.168.101.59
nameserver 192.168.101.58
domain domain.local
search domain.local
Per request here is the Routing table
192.168.101.0       *                   255.255.255.0     U     0      0      0      eth1
192.168.200.0       *                   255.255.255.0     U     0      0      0      eth0
default             192.168.101.254     0.0.0.0           UG    100    0      0      eth1
default             192.168.200.253     0.0.0.0           UG    100    0      0      eth0
Kees Cook
  • 17,823
Dave Long
  • 3,776
You have two default routes. It's possible that your "192.168.101.254" box is not configured to route your traffic out, since you said that that network it's strictly for internal access.
Remove the "gateway" entry from the eth1 network and it should work.
mkm
  • 3,239
keep the gateway entry for eth1 and remove the gateway entry for eth0:
ip route del default dev eth0
create a new policy routing table:
echo "1 admin" >> /etc/iproute2/rt_tables
add the new routes:
ip route add 192.168.200.0/24 dev eth0 src 192.168.200.94 table admin
ip route add default via 192.168.200.253 dev eth0 table admin
add the new rules:
ip rule add from 192.168.200.94/32 table admin
ip rule add to 192.168.200.94/32 table admin
commit the changes:
ip route flush cache
DONE! enjoy! --Jason
hhlp
  • 42,872
