I have Kubuntu 12.04.01 with GIMP 2.06. On a previous installation I used DBP . I found it worked well on resizing images, and want to re-install it. Although I managed before, I cannot now remember how, though there must have been an easy way to do it! Can anyone help, please?
This answer was updated by author in early 2012 ...
Perhaps for you will be actual more to use new versions instead dbp-1.1.5.
Guide by Dave Duncan.
Download the tgz file to your desktop from DBP archive
Open a
terminal, and run the following:sudo apt-get install libgimp2.0-dev gcc cpp g++You may be prompted for a Yes/No answer here (confirming the use of hard drive space). Just type ‘y’ and hit enter. Then, enter the following:
cd /usr/src/In the next command, substitute “[username]” with your username.
Then continue, entering the following commands in turn each time you get a fresh command prompt.sudo tar -xvzf /home/[username]/Desktop/dbpSrc-1-1-5.tgz cd dbp-1.1.5Then build, and install package:
sudo make make installOnce all that is done, open up GIMP and go to (UPDATE Jan.2012):
Filters >> Batch Process
From the dropdown, select Batch Process and the world is your oyster!
Let me know if this works well for you.
Enjoy!
- 3,291
At last I now have DBP in my GIMP in which I acknowledge help from swift (above) the community and the author's blog, which I advise anyone wanting DBP to read.
Whilst I was trying to install, I looked for DBP under the Script Fu tab. It is now under Filters, so I don't know how many of the steps below were actually necessary; anyway here's what I did:
I downloaded http://www.ozemail.com.au/~hodsond/dbpSrc-1-1-9.tgz
There may be a later one, which would amend the following slightly.
Open a terminal, and run the following:
sudo apt-get install build-essential checkinstall
cd /usr/src/sudo tar -xvzf /home/MyUserName/Desktop/dbpSrc-1-1-9.tgz
cd dbp-1.1.9
Then I went to File manager (Dolphin), navigated to root/usr/src/dbp1.1.9. Firstly I right clicked on every file then selected Properties>Permissions to ensure that MyUserName was owner then checked the “is executable” box. I then opened the file Makefile with GNU Emacs and amended the sixth line to read
#NODEPS = -DGTK_DISABLE_DEPRECATED.
Then back to the terminal...
sudo make
make install
I hope that this will help other inexperienced users who want to install this excellent plug-in.
