I'm using ubuntu 10.10 netbook edition. I have some data on a thumb drive that I want to put on my computer but when I plug in the thumb drive, nothing happens. I search for the file and it's not there. /media is empty. How do I mount this thumbrive and make it mount automatically?
output of dmesg. The Total output was too large, so I put in what I thought would be relevant:
[ 2043.086937] wlan0: associated
[ 2523.345076] usb 1-3: new high speed USB device using ehci_hcd and address 3
[ 2523.647942] Initializing USB Mass Storage driver...
[ 2523.648585] scsi4 : usb-storage 1-3:1.0
[ 2523.649787] usbcore: registered new interface driver usb-storage
[ 2523.649796] USB Mass Storage support registered.
[ 2524.660116] scsi 4:0:0:0: Direct-Access     TOSHIBA  TransMemory      5.00 PQ: 0 ANSI: 0 CCS
[ 2524.665393] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 2525.902179] sd 4:0:0:0: [sdb] 4028416 512-byte logical blocks: (2.06 GB/1.92 GiB)
[ 2525.902776] sd 4:0:0:0: [sdb] Write Protect is off
[ 2525.902787] sd 4:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 2525.902795] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2525.906549] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2525.906570]  sdb: sdb1
[ 2525.910640] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2525.910656] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 2638.233056] usb 1-3: USB disconnect, address 3
[ 2643.460114] usb 1-3: new high speed USB device using ehci_hcd and address 4
[ 2643.598968] scsi5 : usb-storage 1-3:1.0
[ 2644.596900] scsi 5:0:0:0: Direct-Access     TOSHIBA  TransMemory      5.00 PQ: 0 ANSI: 0 CCS
[ 2644.599789] sd 5:0:0:0: Attached scsi generic sg1 type 0
[ 2644.819235] sd 5:0:0:0: [sdb] 4028416 512-byte logical blocks: (2.06 GB/1.92 GiB)
[ 2644.819872] sd 5:0:0:0: [sdb] Write Protect is off
[ 2644.819884] sd 5:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 2644.819892] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 2644.825499] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 2644.825533]  sdb: sdb1
[ 2644.834616] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 2644.834632] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 2925.444581] usb 1-3: USB disconnect, address 4
[ 3090.808101] usb 1-3: new high speed USB device using ehci_hcd and address 5
[ 3090.945921] scsi6 : usb-storage 1-3:1.0
[ 3091.944884] scsi 6:0:0:0: Direct-Access     TOSHIBA  TransMemory      5.00 PQ: 0 ANSI: 0 CCS
[ 3091.946451] sd 6:0:0:0: Attached scsi generic sg1 type 0
[ 3093.224574] sd 6:0:0:0: [sdb] 4028416 512-byte logical blocks: (2.06 GB/1.92 GiB)
[ 3093.225499] sd 6:0:0:0: [sdb] Write Protect is off
[ 3093.225517] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 3093.225527] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3093.229707] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3093.229762]  sdb: sdb1
[ 3093.232970] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3093.232993] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 3134.507536] usb 1-3: USB disconnect, address 5
[ 3139.169115] usb 1-1: new high speed USB device using ehci_hcd and address 6
[ 3139.308938] scsi7 : usb-storage 1-1:1.0
[ 3140.308945] scsi 7:0:0:0: Direct-Access     TOSHIBA  TransMemory      5.00 PQ: 0 ANSI: 0 CCS
[ 3140.310423] sd 7:0:0:0: Attached scsi generic sg1 type 0
[ 3140.550352] sd 7:0:0:0: [sdb] 4028416 512-byte logical blocks: (2.06 GB/1.92 GiB)
[ 3140.551040] sd 7:0:0:0: [sdb] Write Protect is off
[ 3140.551059] sd 7:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 3140.551072] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 3140.557789] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 3140.557821]  sdb: sdb1
[ 3140.564267] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 3140.564279] sd 7:0:0:0: [sdb] Attached SCSI removable disk
[ 4639.380928] usb 1-1: USB disconnect, address 6
[ 4749.180094] usb 1-3: new high speed USB device using ehci_hcd and address 7
[ 4749.319077] scsi8 : usb-storage 1-3:1.0
[ 4750.316850] scsi 8:0:0:0: Direct-Access     TOSHIBA  TransMemory      5.00 PQ: 0 ANSI: 0 CCS
[ 4750.319861] sd 8:0:0:0: Attached scsi generic sg1 type 0
[ 4752.278001] sd 8:0:0:0: [sdb] 4028416 512-byte logical blocks: (2.06 GB/1.92 GiB)
[ 4752.278603] sd 8:0:0:0: [sdb] Write Protect is off
[ 4752.278616] sd 8:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 4752.278626] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 4752.283289] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 4752.283320]  sdb: sdb1
[ 4752.289263] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 4752.289286] sd 8:0:0:0: [sdb] Attached SCSI removable disk
oadams
  • 1,341
The thumbdrive should mount automatically. If not, it is quite possible the filesystem is corrupted. Indeed, see the output of dmesg (find the Log File Viewer in System»Administration) and observe any messages that appear as soon as you plug in the thumbdrive.
If the thumbdrive's filesystem is indeed corrupted, there is a process to extract your files, at least some of them.
Update: Try to mount the USB stick manually.
  1. Open a terminal window
  2. Run mkdir /tmp/mountpoint
  3. Run mount /dev/sdb1 /tmp/mountpont
Observe any errors.
If there is no error from the last command, then look into /tmp/mountpoint/ your files should be in there. At this point we can try to figure out why automount does not work.
user4124
  • 9,241
Some options to check (I'd start on points 3 and 5):
  1. Check this question, too: USB Storage Device Automount, and try the solutions proposed there.
  2. Also, you can try palimpsest to mount it (update: you already mounted it, so no need to do this)
  3. In 10.04 (some people reported it with 10.10, too) there seemed to be a bug that prevented usb automounting. Don't know if that's fixed, but you can try the solution for that case (note that it disables floppy support): sudo modprobe -r floppy (source)
  4. Yet another possibility (quoting this):
    I eventually solved this problem by uninstalling pmount, then re-installing together with libpmount0.0
    Now drives are detected, automount and can be safely removed. No idea what caused the problem on the upgrade, but hope that this helps other people with the same problem.
  5. Here you can find another workaround:
    sudo gedit /etc/modules
    Add two lines (at the end of file):
    usb_storage
    usbhid
(Actually you can check with modprobe -l |grep usbhid and modprobe -l |grep usb_storageif those moduled are already loaded or not before doing the edit)
luri
  • 4,132
