I just bought an HP desktop, p6-2326s, which has windows 8 installed. I have tried booting a Ubuntu live disc but the machine won't boot it. When I bring up the UEFI boot menu it offers a selection of UEFI BOOT SOURCES, windows boot manager, dvd drive, IP4 Ethernet controller, or IP6 Ethernet controller. If I select the dvd drive with the CD in it I get the message "Secure boot violation, Invalid structure detected. Check secure boot policy in setup." With all other selections it just boots into windows. So where do I go from here?
Tim
  • 33,500
Disable secure boot in your bios. This will prevent the system from preventing you from running the installer. In the future, versions of GNU/Linux (including Ubuntu) will have workarounds for this feature. For now, complain to Microsoft.
hnasarat
  • 1,826
  • 15
  • 15
Which version of Ubuntu have you tried ?
I think Ubuntu 12.10 64bit supports UEFI mode and secure boot out of the box.
Here is a similar question-answer : 12.10 UEFI Secure Boot install
NickTux
  • 17,865
  • 57
  • 66
  1. With SecureBoot enabled computers, you need to use Ubuntu-Secure-Remix-64bit (or Ubuntu12.10 64bit)
  2. If the error persists, disable SecureBoot in your firmware as described here: https://help.ubuntu.com/community/UEFI#SecureBoot , and try again.
  3. Once you can boot the Ubuntu disk, install Ubuntu and use Boot-Repair's Recommended Repair as described in the first paragraph of https://help.ubuntu.com/community/UEFI
LovinBuntu
  • 3,785
