I've been trying to install the Boinc software (http://boinc.berkeley.edu/), I could do it in Ubuntu 12.04 but it never worked as well as in Windows (couldn't get it on the systray icons, to be a startup application etc.), but in Ubuntu 12.10 I can't even install it to get the interface, there's a lot of versions and ways to install it.
Anyone knows the correct way for installing and using Boinc in Ubuntu?
Thanks!
amc
  • 7,292
Graphical Installation
You need to install the client software, which will act as a daemon and boinc client will be automatically started at boot time.
Command to install boinc-client
sudo apt-get install boinc-client
You need the boinc manager to have a graphical interface to monitor and control boinc client.
Command to install boinc-manager
sudo apt-get install boinc-manager
Both the above commands can be combined and run together as
sudo apt-get install boinc-client boinc-manager
To open Boinc Manager. Use dash(Super Key) and search for "boinc"
Non-Graphical Installation
If you are not looking for a graphical interface you just need to install boinc-client
Via Ubuntu Software Center
You can also use Ubuntu Software Center to install Boinc. Search for "boinc-client" in Ubuntu Software Center.
Install via the software center
devav2
  • 37,290
Just install it using the package manager. Package names: boinc and boinc-manager. E.g.:
And it should be available in the regular application menu.
Jorge Castro
  • 73,717
gertvdijk
  • 69,427
