I have HP Probook 4530s and the fan speeds up at around 45C then when it reaches 35C slows down and repeats. In the interval between 35-45 it barely works and this results in very annoying speed up of the fan every 2 minutes. How can set a higher threshold at which it will speed up and how can I keep the tempreture between the two intervals stable ( I mean the fan will not turn off but keep a steady speed ). Thank you in advance.
Asked
Active
Viewed 726 times
Fan speed and the temperature at which the fan hits certain speeds can be controlled in linux via a combination of packages lm-sensors and fancontrol, though on my HP laptop I could never get it to work properly, I believe because HP controls this via the bios, but it may just be I didn't research enough.
I ended up changing the cpu governor to conservative and changing the conservative governor settings this ultimately made my computer run cooler and more efficiently (less fan cycling).
I found these two pages that helped me manipulate the governor and put my setting permanently in /etc/rc.local to load them on each reboot http://www.pantz.org/software/cpufreq/usingcpufreqonlinux.html http://www.thinkwiki.org/wiki/How_to_use_cpufrequtils
