I burnt the USB stick with the Ubuntu ISO, and can readily install Ubuntu with that pendrive. But when I plug it in Windows, Windows does not detect it.
Can I make Windows recognize it.
you should know, that windows only recognizes file-formats like FAT NTFS and else DOS-formats
when usb-stick has an unix-filesystem it happens that it is not readable for windows, unless you use the correct drivers.
Check this out:
http://sourceforge.net/projects/ext2fsd
Its a program/driver to be able to browse ext2/3/4 filesystems from windows.
Source(s): http://www.linuxjournal.com/article/9449
