After update to Kubuntu 12.10, I can no longer access configuration options in Kile from Settings->Configure kile (or whatever the menu entry was for configuration).
In fact, "Settings" menu has only five entries: "Define current document as master document", "System check", "Show side bar", "Show message bar", and "Toolbars shown."
I did a fresh install of Kubuntu 12.10 on one of my other computers, and same problem. I even tried adding the (unsupported) ppa:kile/stable, but the problem persists. Any ideas?
I need to access settings to set PDF Latex to use "modern" compilation mode, so that I can use synctex.
Try removing the user specific file for Kile. I had the same problem after I messed with the toolbars.
~$ rm ~/.kde/share/apps/kile/kileui.rc
These guys had the had the same problem. They suggest the folder ~/.kde4 where on my system 12.10 (64) it was in ~/.kde.
My installation of Kile lost the entries in the settings dialogue as soon as I changed one item in any of the toolbars. My solution for this might help you out as well.
It appeared I could avoid this by adding the button "Configure Kile" to a toolbar.
This approach retains your personalised toolbars.
My sytem: Kile 2.1.0 / KDE 4.9.4 @ Kubuntu 12.04
gertvdijk
  • 69,427
Erik
  • 81
Another way of getting system settings back is by resetting your toolbar: right click the toolbar, select "Configure Toolbars...", and then click the "Defaults" button on the lower left.
I've found another solution for this...
vim ~/.kde/share/config/kilerc
there I edited the MainWindow configuration, just search the word MainWindow using
/KileMainWindow
and edited the keyword value named MenuBar. I founded it configured like this:
MenuBar=Disabled
after that I switched to able.
Saved the file, re-launch Kile and worked perfectly.
Bruno
