49
Usually I upgrade my Ubuntu installation through a ssh connection. Sometimes this ssh connection would be lost or I would accidentally close the terminal window.
It is possible to check the upgrade status after a ssh re-login into the computer?
Josema
  • 603
7 Answers7
62
The following logs are related to apt upgrades:
/var/log/apt/history.log
/var/log/apt/term.log
/var/log/dpkg.log
If the command was dist-upgrade, there are additional logs in:
/var/log/dist-upgrade
FYI, it is usually safe to just re-run the upgrade and apt will continue where it left off when the process died due to disconnection. However...
A GNU Screen Primer:
When ssh'ing into a remote server and starting a long-running process in the foreground, it is best practice to use GNU Screen. Screen provides a virtual terminal that continues running even if your ssh connection is lost.
Install screen:
sudo apt-get install screen
Run screen:
screen
After running screen you will get a command line prompt as with a normal terminal. You can then run the upgrade from inside screen:
sudo apt-get upgrade
To understand how this works, "detach" screen by pressing Ctrl+a, d. This will return you to the non-screen terminal. You can see the list of running screens with
screen -list
If you only have one screen running, you can reattach it with:
screen -raAd
(This detaches screen in case it is attached elsewhere, and reattaches it to the terminal you are currently running.)
Typically you cannot scroll 'normally' from within screen without some extra setup. To scroll within screen, press Ctrl-Esc to enter cursor mode. You can then scroll down and up with j and k. Press Esc again to exit cursor mode.
There are many more resources on the net available for additional screen functions. It is an invaluable standard tool for system administration.
See also:
28
I had an upgrade in progress (asking me whether to keep or replace a config file; this information I took from /var/log/apt/term.log) when my terminal was closed by another person. Restarting apt upgrade complained about a lock file being held.
My fix was to do the following:
sudo killall apt # to release the lock
sudo dpkg --configure -a # to fix the interrupted upgrade
sudo apt upgrade # to make sure no packages are left not upgraded
Ruslan
  • 1,863
26
To see real-time output from background apt job, use:
sudo tail -f /var/log/apt/term.log
14
In addition to doublerebel's answer, I noticed an alternative today.
I went to bed last night after starting an upgrade over SSH. I stupidly forgot to start it in screen and lost my SSH session overnight.
I was just about to start researching retty when I noticed that root had started a screen session.
me@GAMMA:~$ ps aux | grep -E 'release|upgrade|apt'
root      6208  0.0  0.0  29140  1628 ?        Ss   01:57   0:05 SCREEN -e \0\0 -L -c screenrc -S ubuntu-release-upgrade-screen-window /tmp/ubuntu-release-upgrader-1h6_g4/raring --mode=server --frontend=DistUpgradeViewText
root      6209  0.2  5.6 287428 93144 pts/2    Ss+  01:57   3:13 /usr/bin/python /tmp/ubuntu-release-upgrader-1h6_g4/raring --mode=server --frontend=DistUpgradeViewText
root      6239  0.0  0.0  50052  1184 ?        Ss   01:58   0:00 /usr/sbin/sshd -o PidFile=/var/run/release-upgrader-sshd.pid -p 1022
root      7306  0.0  4.6 287432 77284 pts/2    S+   02:43   0:08 /usr/bin/python /tmp/ubuntu-release-upgrader-1h6_g4/raring --mode=server --frontend=DistUpgradeViewText
me       26829  0.0  0.0   9440   956 pts/5    S+   22:18   0:00 grep --color=auto -E release|upgrade|apt
So I listed root's screens and attached to it:
me@GAMMA:~$ sudo screen -list
There is a screen on:
        6208.ubuntu-release-upgrade-screen-window       (12/11/2013 01:57:58 AM)        (Detached)
1 Socket in /var/run/screen/S-root.
me@GAMMA:~$ sudo screen -x -r
And Bam! I was back in the game.
Huckle
  • 7,258
This post helped me to do better in the future: use 'screens'
This Debian post helped me to fix my acute problem:
https://wiki.debian.org/Teams/Dpkg/FAQ
sudo fuser -vki -TERM /var/lib/dpkg/lock /var/lib/dpkg/lock-frontend
sudo dpkg --configure --pending
TheGlasses
  • 149
Had exactly the same issue, lost my connection and the dpkg process was waiting for input.
Maybe next time try: sudo dpkg --configure -a
TL;DR: After losing ssh connection you might have an unreachable console dialog blocking your upgrade from continuing. Kill the whiptail process to allow it to continue.
I had a similar problem and while some of the answers were useful, they didn't help me resolve my problem. But between @Huckle's answer and @CivMeierFan's 2nd comment on @Sebastian Faujour's answer, I found my way forward.
"ps aux | grep -E 'release|upgrade|apt'" showed a whiptail process (also shown with "/var/log/apt/term.log", but in that case it just dumped an unusable console prompt. Helpful to understand why the upgrade was blocked, but not helpful for resolving the problem).
Killing the whiptail process allowed the upgrade to continue.
ajh158
  • 209
