16
Recently I found out about an OS X application called LESS.app. It’s basically an app to compile and minify *.less files into *.css files and does it in real-time. I want to know or I can archive the same thing in Ubuntu and how to go about it.
Jorge Castro
  • 73,717
Mood
  • 802
6 Answers6
25
Bryan here. Developer of Less.app.
I highly recommend AGAINST using the older version of LESS (the Ruby-based one). Less.js isn't just a javascript port of LESS, it's a ground-up rewrite that improves a ton of stuff, adds support for things that the old Ruby version doesn't have, and increases compiler speed by about 84%.
Rather than install the Ruby gem, install Node.js and run Less.js through Node from the command line. You'll still have all the -watch functionality, but you'll be using Less.js to do it, which means your life will be much better.
Alternately, use Less.js as a script in the website you're creating. This will work for development. When you're done coding, simply copy the CSS that Less.js generates (from your browser's inspector) and place that into a file, add a .css extension, then remove the Less.js script tag from the HTML pages and substitute the CSS file you just created.
Either way, use Less.js.
Rob W
  • 2,307
Bryan
  • 266
Note
Read Bryan's answer. He knows what he's talking about. ;-)
You can just install less.
  1. Install rubygems and less
    sudo apt-get install rubygems
    sudo gem install less
  2. The official documentation remarks:
    To make gem work properly you should write gem's path to PATH add to ~/.bashrc:
     export PATH=/var/lib/gems/1.8/bin:$PATH
  3. You can then use the less compiler by doing
    lessc style.less
I don't think there's a GUI like the one you've linked to. But since it only seems to be a very shallow gui on top of the real less compiler, I don't think you'll have any problems using it directly. Type
lessc --help
to learn how to use it.
If you want your .less files to be automatically compiled every time you change them, you can use the -w option:
~$ lessc test.less -w
* Watching for changes in test.less... Ctrl-C to abort.
: Change detected... * Updated test.css
You can put this process in the background by pressing Ctrl+Z and typing bg, and start as many as you like. You can bring them back to the foreground by doing fg, or fg 3 for the third process, to get a list of all of the jobs and their numbers type jobs.
Under Ubuntu 11.10, you can simply issue a
sudo apt-get install lessc
Prav
  • 332
To my knowledge, ruby less isn't updated enough to even handle the concatenation operator.
For those interested in a solution that compiles .less upon save for non mac platforms using less.js, you can check out this installation guide*. Though the tutorial is geared towards Windows users, I imagine if you can get Node.js on your system, the script itself will function the same.
*Disclaimer: This tutorial is mine. Just thought people might want to see specifically what the poster above meant by "Use Node.js". I wasn't able to find any scripts online for using Node.js to compile LESS upon file save, so I cooked one up and thought I would share it.
you can install it the command line compiler in Ubuntu 12.10 as well:
sudo apt-get install node-less
JoZ3
  • 639
There's also http://koala-app.com/.
http://crunchapp.net/ was my favorite, but we have to thank Adobe for discontinuing AIR for Linux.
Alix Axel
  • 1,073
