Where can I get new Aegisub? Ubuntu reps have only 2.1.9 which is VERY buggy (it doesn't support cyrillic lower case, it's unaceptable for me). I found only source, but I'm not sure, that I can do everything right. Where to get new package (at least newer)?
Asked
Active
Viewed 2,266 times
You have two options: compile from source (which is easy if you follow the instructions) or use a precompiled package for 12.04 with your 12.10 version. In both cases you will get aegisub 3.0.1.
Install from precompiled package
On this page someone provides precompiled packages of aegisub and wxWidgets (install both packages) for Ubuntu 12.04. Despite the warning that the package is of low quality, the installation should work with Ubuntu 12.10 as well.
Compile from source
I've found step by step instructions in the aegisub forum. Please take a look at the post, the poster explains all steps.
A short version in case the link goes down:
- Install dependencies: Open a terminal (CTRL+ALT+T) and insert the following:
sudo apt-get install build-essential libasound2-dev libass-dev libffms2-dev libfftw3-dev libgl1-mesa-dev libglu1-mesa-dev libgtk2.0-dev libhunspell-dev liblua5.1-dev checkinstall - Build wxWidgets by entering the following into the terminal (line for line):
cd ~
wget http://sourceforge.net/projects/wxwindows/files/latest/wxWidgets-2.9.4.tar.bz2
tar xjf wxWidgets-2.9.4.tar.bz2
cd wxWidgets-2.9.4
./configure --with-opengl
make
sudo checkinstall
sudo ldconfig - Build aegisub by entering the following into the terminal (line for line):
cd ~
wget http://ftp.aegisub.org/pub/releases/aegisub-3.0.1.tar.xz
tar xJf aegisub-3.0.1.tar.xz
cd aegisub-3.0.1/aegisub
./configure
make
sudo checkinstall
mrcktz
- 1,774
