I've recently downloaded Ubuntu 12.10 and it seems great. I just can't get my Three Ireland mifi dongle to work at all. When I plug it in, it only recognizes it as a storage devise. Any ideas on how to establish a permanent connection to this mifi dongle? I'm in Ireland and running a Dell Inspiron 1520 with 3GB of RAM and using the Huawei E586 mifi device. I really want to continue using this OS, but is everything this complicated to get up and running on it?
TRiG
  • 2,006
You can resolve this by:
(a.) Plugging in a USB WiFi adapter to your Dell laptop, or using its inbuilt WiFi capability, OR
(b.) Finding the correct USB mode-switch settings, so that it (your USB device) switches back to being a modem (and not just a storage device).
Some Background:
Back in Windows-land, someone had the 'bright' idea that, as all devices need a 'new' driver, any newly plugged-in device should first 'pretend' to be a USB storage device - and attempt to auto-load the driver (stored for that purpose on the device). Then, when the driver starts up it knows to send a command to switch the USB device back into being 'whatever'.
However, Linux (and in particular Ubuntu) does not need lots of new drivers. More importantly, having a device attempt to auto-load a driver (or any executable code) is plain dangerous - and may also breach security policy and/or be prevented by anti-virus software (or similar protective measures).
Instead Ubuntu (and other Linux variants) provides the 'USB mode switch' function, complete with a large (and growing) list of brands / devices, and the data needed to control them. Unless you are using an unusual (or new) device, a simple update will usually resolve these sorts of issues.
david6
  • 14,528
  • 38
  • 46
Drivers off the Huawei site worked perfectly for me! Make sure you read the instructions and it's easy going, took about 30 seconds. http://consumer.huawei.com/en/support/downloads/detail/index.htm?id=13971
