Anyway....there is Ubuntu 12.04 LTS and the normal 12.10 version. Is that the same with Lubuntu? On their site, for some reason, they seem to be promoting the 12.10 version while for me an LTS is always more appealing. I am wondering if they have the same ideology as the Ubuntu team.
UPDATE: Is it okay to talk about Lubuntu here at all? I understand that it is a flavour of Ubuntu...but still. Are they 2 very different teams?
Tim
  • 33,500
Elysium
  • 11,142
No, but also yes. You will receive 5 years support on packages Ubuntu provides support for this term.
Lubuntu shares packages with Ubuntu in a sense that "underlying" "base" software like Alsa, the kernel, common shared libraries and such are from the same archive and maintained by the same people. Lubuntu is nothing more than Ubuntu with another set of preselected set of packages. It's just that Unity comes with 5 years of support and LXDE doesn't, in Ubuntu.
For the example of the kernel, Unity and LXDE core, run this on Lubuntu 12.04 or Ubuntu 12.04 (won't make a difference):
$ apt-cache show linux-image-generic | grep ^Supported
Supported: 5y
$ apt-cache show unity | grep ^Supported
Supported: 5y
$ apt-cache show lxde-core | grep ^Supported
<no output>
This way, you can check for every package whether it comes with the 5 years of support or not.
So, this makes me disagree with the other answer stating
Also, please note that if you are using Lubuntu, instead of Ubuntu, you will not receive LTS since Lubuntu 12.04 isn't an LTS release.
Because, regardless of how you installed Lubuntu1, you will receive updates for 5 years, yet not for all of your packages (including LXDE).
1 You can install Lubuntu in two ways. 1) Install regular Ubuntu first, replacing Unity with LXDE via the lubuntu-desktop^ apt-task and selecting it in your login screen as desktop environment to log in to, or 2) using the Lubunu Live CD/installer directly.
gertvdijk
  • 69,427
Yes. You will still receive security updates for your Ubuntu machine if you are using Long Term Support (LTS). However, not all applications will receive security updates since the LTS designation only applies to certain parts of the Ubuntu Archive.
Examples of applications that may receive security updates are those which are supported by the Ubuntu Team or Canonical such as Ubuntu One or Firefox.
Source: An explanation of LTS in the Ubuntu Wiki
camconn
  • 1,894
No.
Unlike Ubuntu, Lubuntu 12.04 is not a LTS, this version will be supported for 18 months. However, a lot of work has been done to improve the stability of the system.
Source
Note: Lubuntu 12.04 is not LTS, but it's based on Ubuntu 12.04 LTS. So it's very stable, the same way as Ubuntu 12.04 LTS. I'd like to recommend to you to upgrade your system to Lubuntu 12.10.
You can check the differences of Lubuntu 12.10 to Lubuntu 12.04 at this link.
Zignd
  • 10,982
-2
If you don't want a bloatware of packages and software on your machine, just install Lubuntu 12.04, but again it's not LTS. To get this "LTS" version of Lubuntu, you have to install Ubuntu 12.04 and then open the terminal and install:
sudo apt-get install lubuntu-desktop
But again, you still have a bloatware of packages that came with Unity and Ubuntu-desktop and you need to purge a lot of stuff to get pure Lubuntu desktop and you should be careful when doing this. And another thing is, you gonna using unity greeter lightdm instead of the lubuntu lightdm version.
