I'm trying to launch one command in a new gnome-terminal window from a shell script, and it seems that my .bashrc file doesn't get sourced when calling gnome-terminal and executing a command:
gnome-terminal -t "my title" -e vim
But it does when launching gnome-terminal alone:
(for testing purposes, just add a echo "something" to the end of the .bashrc)
I also tried explicitly sourcing the .bashrc before running vim with no success:
gnome-terminal -t "my title" -x $SHELL -c "source $HOME/.bashrc; vim"
Am I missing something?
No, your are correct. gnome-terminal does not source .bashrc when running a command via the -e argument.
Bash and gnome-terminal are two separate things. When you run without -e gnome-terminal runs your default shell (which happens to be bash). When you run with -e gnome-terminal runs the command you provided (bash is not loaded so .bashrc is not sourced).
Your last example will not work either. $HOME is a variable in bash and not available. In addition source is a bash command, and vim likely needs a path.
The best way to do this, in my opinion is to make a wrapper script.
In your path somewhere (I added ~/.bin/ to my path) create a file called vim-x and set it executable.
#!/bin/bash
vim "$@"
Then you can run:
gnome-terminal -t "my title" -e /home/user/.bin/vim-x
coteyr
  • 18,724
I found the problem with the help of this reply.
Actually the .bashrc was sourced, but not completely processed because of the following lines:
# If not running interactively, don't do anything
[ -z "$PS1" ] && return
To bypass the problem, the cleanest approach would be to force the shell instance to be run in interactive mode (as seen here):
gnome-terminal -t "my title" -x $SHELL -ic "vim"
