I use the inverted colors mode a lot, however after installing ubuntu 12.10 it doesn't work for me any more. The command:
xcalib -i -a
Outputs:
Error - unsupported ramp size 0
I have no clue where to start looking to fix this problem. Couldn't find anything about this error. Any ideas?
kar
  • 163
The gamma ramp is not defined (0), but xcalib expects multiples of 16. Installing gcm solved the issue for me:
sudo apt-get install gnome-color-manager
Eric Carvalho
  • 55,453
Here's an idea (I had the same problem with Xubuntu 17.10.1, and this solution worked for me): Use the solution provided in Anwar's answer to this question.
Create the following filepath (I had to make the directory called xorg.conf.d, too): /etc/X11/xorg.conf.d/20-intel.conf and add these lines to the file (then save and restart your computer afterward):
Section "Device"
  Identifier "Intel Graphics"
  Driver "intel"
EndSection
