I have some bad sectors on my hard drive, so I followed the guide from this website
To detect the bad sectors, I did the following command:
sudo badblocks /dev/sda5 > /media/3865-6163/sda5
That worked fine, the next step is to run the following command:
sudo fsck -l /media/3865-6163/sda5 /dev/sda5
For some reason, this does not work for me and gives me the following message:
ubuntu@ubuntu:/media/3865-6163$ sudo fsck -l /media/3865-6163/sda5 /dev/sda5
fsck from util-linux 2.20.1
Usage: fsck.ext4 [-panyrcdfvtDFV] [-b superblock] [-B blocksize]
        [-I inode_buffer_blocks] [-P process_inode_size]
        [-l|-L bad_blocks_file] [-C fd] [-j external_journal]
        [-E extended-options] device
Emergency help:
 -p                   Automatic repair (no questions)
 -n                   Make no changes to the filesystem
 -y                   Assume "yes" to all questions
 -c                   Check for bad blocks and add them to the badblock list
 -f                   Force checking even if filesystem is marked clean
 -v                   Be verbose
 -b superblock        Use alternative superblock
 -B blocksize         Force blocksize when looking for superblock
 -j external_journal  Set location of the external journal
 -l bad_blocks_file   Add to badblocks list
 -L bad_blocks_file   Set badblocks list
Why is this not working?
