if i try and compile the tutorial code for GTK3 with the command
gcc simple.c -o simple 'pkg-config --libs --cflags gtk+-3.0'
it gives off the error
gcc: error: pkg-config --libs --cflag gtk+-3.0: No such file or directory
However if i run the command
pkg-config --libs --cflag gtk+-3.0 > makefile
and then edit the makefile such that the output of the above command is after
then it compiles with no problems at all. What gives?
I got this problem too, but after carefully see the the code, it just a typo. Please see again your command,
It should be,
gcc simple.c -o simple `pkg-config --libs --cflags gtk+-3.0`
Can you see the different? The ' should be `. It works for me!
sugab
  • 4,417
