After I got Steam running with the workaround mentioned here, I've got nearly the same problem when launching Team Fortress 2.
After starting it from Steam the "Launcher" pops up and after a few seconds it disappears with the following error in the terminal:
/home/user/Steam/SteamApps/steamuser/Team Fortress 2/hl2_linux: error while loading shared libraries: libGL.so.1: wrong ELF class: ELFCLASS64
Game removed: AppID 440 "Team Fortress 2", ProcID 5299
saving roaming config store to 'sharedconfig.vdf'
roaming config store 2 saved successfully
Because of the similarity with the workaround I used before, I tried to execute:
export LD_LIBRARY_PATH=/usr/lib32:$LD_LIBRARY_PATH
directly before launching the game, but there is no difference.
stefanhgm
  • 111
I found the solution here:
Or, instead of editing the file ld.so.conf directly, create a file called local.conf in the subdirectory /etc/ld.so.conf.d containing just the line /usr/local/lib. That is,
Contents of /etc/ld.so.conf.d/local.conf:
/usr/lib32
Then run the sudo ldconfig command.
stefanhgm
  • 111
