10
I have several programs that reuquire 32 bit packages (pointing to the ia32-lib package). However, when I try to install it, this happens.
spirit@ubuntu:~$ sudo apt-get install ia32-libs
Reading package lists... Done
Building dependency tree
 ia32-libs : Depends: ia32-libs-multiarch but it is not installable
No big whoop, packages die all the time. I tried a month later however and I still got this error, trying to install the specific package produces this error.
spirit@ubuntu:~$ sudo apt-get install ia32-libs-multiarch
Package ia32-libs-multiarch is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ia32-libs-multiarch' has no installation candidate
I am no Linux whizz-kid, but this seems to be that the package doesn't exist. I searched for Skype in the software centre (I was told this installs the 32-bit packages) and it does not appear in the software centre, and the downloadable from their website produces an error about - funnily enough - no 32-bit packages.
Anyone who helps me will get a medal from the gods with the weight of a thousand planets. Just don't wear it for god's sake.
Jorge Castro
  • 73,717
soup-bowl
  • 103
6 Answers6
12
Sounds like installing through WUBI did not correctly detect the available foreign architectures. As tumbleweed suggested printing the foreign architectures probably returns nothing. Add i386 as a foreign architecture, update the apt cache, then install the 32 bit libs.
sudo dpkg --add-architecture i386 && sudo apt-get update && sudo apt-get install ia32-libs
Scotty's answer works great for 12.10, but if you are on 12.04, then dpkg does not support --add-architecture. Just try:
sudo apt-get update
and then try installing ia32-libs as
But it is probably better to install the meta package ia32-libs-multiarch instead.
Eric Carvalho
  • 55,453
  • Install Synaptic from terminal window
    sudo apt-get install synaptic
  • Launch Synaptic and goto “settings > Repositories”
  • Click “other software > add”
  • Insert this line in the box deb http://archive.ubuntu.com/ubuntu/ raring main restricted universe multiverse
  • Click ok and close Synaptic
  • In terminal sudo apt-get update
  • In terminal sudo apt-get install ia32-libs
  • Fresh Install
BuZZ-dEE
  • 14,533
Sîpan Roj
  • 23
Have you tried to install them from the Ubuntu Software Center? It should locate us directly the package we're looking for. Search for "ia32", locate ia32-libs-multiarch:i386 and ia32-libs and install them.
If that doesn't solve the problem, try changing the server from Edit > Software Sources and run update from Update Manager or sudo apt-get-update before trying to install again.
Inoe
  • 337
Package ia32-libs is not available, but is referred to by another package ! Installation Error
While installing kingsoft office I faced OS bit version problem ( a well known error but without proper answer) The following packages have unmet dependencies: ia32-libs: Depends: ia32-libs-multiarch but it is not installed . I tried ~50 solutions but none of them worked. After that I followed ubuntu terminal instruction and omg it has solved my problem.
When I fired the command I got following message,
Package ia32-libs is not available, but is referred to by another package.
However the following packages replace it:
  lib32asound2 lib32z1 lib32ncurses5 lib32bz2-1.0
After that I tried to install all the above mentioned pkg one by one and after installing "lib32z1" my problem was solved :)
sudo apt-get install lib32z1
sudo apt-get install lib32ncurses5
sudo apt-get install lib32bz2-1.0
-1
If you are having this problem, it's most likely you are on Precise 64-bit with Amazon EC2. They have fixed this for Ubuntu 12.10.
