We have setup Apache Solr on Rackspace dedicated ubuntu server. But, I think because of Firewall this service is not available. I tried adding following line as per Rackspace documentation:
/sbin/iptables -I RH-Firewall-1-INPUT 1 -p tcp --dport 8983 -j ACCEPT
which returns me following result:
iptables: No chain/target/match by that name.
Please find below the result from the command iptables -L -n:
Chain INPUT (policy DROP)
target prot opt source destination
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:80
fail2ban-ssh tcp -- 0.0.0.0/0 0.0.0.0/0 multiport dports 22
ufw-before-logging-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-before-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-reject-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-track-input all -- 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy DROP)
ufw-before-logging-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-before-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-reject-forward all -- 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-before-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-reject-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-track-output all -- 0.0.0.0/0 0.0.0.0/0
Chain fail2ban-ssh (1 references)
RETURN all -- 0.0.0.0/0 0.0.0.0/0
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:137
ufw-skip-to-policy-input udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:138
ufw-skip-to-policy-input tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:139
ufw-skip-to-policy-input tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:445
ufw-skip-to-policy-input udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:67
ufw-skip-to-policy-input udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:68
ufw-skip-to-policy-input all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ufw-user-forward all -- 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-input (1 references)
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
ufw-logging-deny all -- 0.0.0.0/0 0.0.0.0/0 state INVALID
DROP all -- 0.0.0.0/0 0.0.0.0/0 state INVALID
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 3
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 4
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 11
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 12
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 8
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp spt:67 dpt:68
ufw-not-local all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT udp -- 0.0.0.0/0 224.0.0.251 udp dpt:5353
ACCEPT udp -- 0.0.0.0/0 239.255.255.250 udp dpt:1900
ufw-user-input all -- 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output all -- 0.0.0.0/0 0.0.0.0/0
Chain ufw-logging-allow (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN all -- 0.0.0.0/0 0.0.0.0/0 state INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type LOCAL
RETURN all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type MULTICAST
RETURN all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
ufw-logging-deny all -- 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 state NEW
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 state NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:22 /* 'dapp_OpenSSH' */
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:1111
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:1111
ACCEPT all -- 174.143.23.0/25 0.0.0.0/0
ACCEPT all -- 50.56.142.128/26 0.0.0.0/0
ACCEPT all -- 180.150.149.64/26 0.0.0.0/0
ACCEPT all -- 69.20.52.192/26 0.0.0.0/0
ACCEPT all -- 78.136.44.0/26 0.0.0.0/0
ACCEPT all -- 50.57.61.0/26 0.0.0.0/0
Chain ufw-user-limit (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 5 LOG flags 0 level 4 prefix "[UFW LIMIT BLOCK] "
REJECT all -- 0.0.0.0/0 0.0.0.0/0 reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
Please guide me to the right direction.
Thanks, Vishal
