I can't connect my Alcatel X200 in Ubuntu 12.04 Precise Pangolin. I search some information, and i think is the kernel but i don't know how can i fix it.....
modeswitch work well because the "lsusb" return:
Bus 004 Device 001: ID 1bbb:0000 T & A Mobile Phones
but when i try to add a new connection Ubuntu don't recognize it.
Can somebody help me??
Thank you very much! You has solved the problem that I have three years fixing. but, the connection is "invisible". Is like i'm disconnect, the icon of the connections is a triangle with the top line curve. Is ok? Can i do "visible" the connection?
I can't install nothing in the ubuntu software center, and Ubuntu One doesn't synchronize my files...
Thank you again!
jrg
  • 61,707
Woshi
OK, try to avoid Network Manager, install and use usb-modeswitch with wvdial instead.
Edit /etc/wvdial.conf as follows:
[Dialer Defaults]
Modem = /dev/ttyUSB1
Baud = 460800
Modem Type = USB Modem
Init1 = ATZ
Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
Phone = *99#
Dial Command = ATDT
Username = INSERT DEFAULT USERNAME HERE (ask Your provider)
Password = INSERT DEFAULT PASSWORD HERE (might me the same, ask Your provider)
Stupid Mode = 1
Dial Attempts = 1
Open a terminal window or switch to another virtual console.
Run sudo wvdial to connect and press Ctrl+C to close the connection.
If this fails you can try substituting other devices for the Modem = /dev/ttyUSB1 line, such as:
/dev/ttyUSB2
/dev/ttyUSB3
Eric Carvalho
  • 55,453
init
