I have accessed my crashed Ubuntu version via live USB trial. Where am I supposed to find my former Firefox bookmarks and history files in order to copy and transfer them into a new installation?
The easiest thing to do would be copying the Firefox profile folder over
~/.mozilla/firefox/xxxxxxxx.default
http://kb.mozillazine.org/Profile_folder_-_Firefox#Linux
The bookmarks are actually stored in bookmarks.html if you just want that.
- 10,185
If you have never used the firefox option Bookmarks->Show All Bookmarks-> Import and Backup -> Export Bookmarks to
HTML, then you will never see a file, bookmarks.html.
In such a case, you can probably copy over the history files stored in
~/.mozilla/firefox/xxxxxxxx.default/bookmarkbackups/
where xxxxxxxx.default is a FF assigned directory.
And then, don't forget to export the bookmarks to wherever you want them.
It will be stored at /bookmarks.html
- 61
You can simply copy the old .mozilla folder into your home folder, after which you can select the appropriate backup through Import and Backup → Restore within FireFox (or IceCat) under Bookmarks → Show All Bookmarks.
- 153
- 1
- 9
If you haven't exported your bookmarks to a bookmark.html file, you can still replace your current bookmarks with your old ones :)
- Click on Bookmarks->Manage Bookmarks or simply use
Ctrl+Shift+O. - Select Import and Backup->Restore->Choose file
- Navigate to your old
.mozillafolder. make sure you right click Show Hidden Files - Keep the JSON preselected filter on and in one of the folders of under the
firefoxdirectory you should find abookmarkbackupsfolder. Simply click on the latest.jsonfile!
- 101
