I am getting a
port 22: Connection refused
error while connecting to a server.
I have both the openssh client and server installed, and they are running. But still there is an error. Please help.
While on the server, check to make sure sshd is actually running, and is listening on port 22:
$ sudo netstat -anp | grep sshd
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1538/sshd
tcp6 0 0 :::22 :::* LISTEN 1538/sshd
If you don't get results, or they don't show you're listening on tcp 0.0.0.0:22... fix that.
If you DO show that sshd is running and is listening on tcp port 22, check to make sure there's no firewall rule getting in the way. Again, on the server:
$ sudo iptables -L | grep ssh
DROP tcp -- anywhere anywhere tcp dpt:ssh
Or alternately,
$ sudo ufw verbose
Status: active
To Action From
22 DENY Anywhere
22/tcp DENY Anywhere
If you do see a rule like one of the ones above, you'll need to fix that.
If you don't see any firewall rules in the way and you do see the service running on the server, then it's time to check your workstation, and the network it's connected to. Can you connect to other servers? Can you ping your own interface or loopback address? Etc.
Try this
sudo apt-get remove openssh-client openssh-server
and then
sudo apt-get install openssh-client openssh-server
it worked for me :)
Probably not the most orthodox solution... :)
Came across same problem after installing Raspbian. Solution that worked for me:
sudo apt-get purge openssh-server
sudo apt-get install openssh-server
The following commands worked for me:
cd /root/.ssh
vi known_hosts
Now delete everything in that file and enter on the terminal:
service sshd restart
Source: SSH - Connection Refused
This might fix it for you as well. Try port forwarding connection 22 from your outgoing IP address to your local IP on the same port. Worked for me allowing me to ssh in to remote ubuntu computer.
