11
As my built-in NIC was not supported by Ubuntu out-of-the-box I was forced to use a USB NIC for temporary installation-time Internet connection.
And the USB NIC has taken the eth0 name making the built-in NIC to become eth1.
Sure, this doesn't really matter but just for the system "prettiness" I would like eth1 to become eth0 letting any newly attached NIC to become eth1.
Is this possible?
Ivan
  • 58,745
It is possible. Please do:
gksudo gedit /etc/udev/rules.d/70-persistent-net.rules
Swap eth0 and eth1. Proofread carefully, save and close gedit. Use any other text editor if you don't have gedit. Reboot immediately and you should be all set.
Rinzwind
  • 309,379
chili555
  • 61,330
11
This renames em1 to eth0 for me on Ubuntu 14.04:
# Note: replace xx:xx... in the rule with the MAC address of your Nic>
$ sudo vim /etc/udev/rules.d/75-persistent-net-generator.rules
SUBSYSTEM=="net", ACTION=="add", ATTR{address}=="xx:xx:xx:xx:xx:xx", NAME="eth0"
# Change "em1" to "eth0" in your interfaces file.
$ sudo vim /etc/network/interfaces
$ sudo reboot
Credit: Billf's answer here: https://bbs.archlinux.org/viewtopic.php?id=156375
FYI, this was what I was originally seeing in logs:
$ sudo grep eth0 /var/log/dmesg
[    2.976463] e1000e 0000:00:19.0 eth0: registered PHC clock
[    3.003714] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 18:03:73:e9:f2:36
[    3.031177] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    3.058399] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: E041FF-0FF
[    3.153759] systemd-udevd[167]: renamed network interface eth0 to em1
Looks like systemd-udevd was doing negative work and renaming eth0 to em1 in the first place. Not sure how to stop it from doing that, but renaming back to eth0 seems to work.
For the enthusiast who wants to know more... http://linux.dell.com/files/whitepapers/consistent_network_device_naming_in_linux.pdf
user79878
  • 211
In Ubuntu Server 16.04LTS the 70-persistent-net.rules doesn't exist and a lot of posts didn't help. After 4 hours of searching I came up with this solution, and to my shock it actually worked!
sudo ln -s /dev/null /etc/udev/rules.d/80-net-setup-link.rules
Then create the file using sudo vi /etc/systemd/network/10-internet.link and add the following
[Match] Path=pci-0000:(your device mac address)
[Link] Name=eth0 (or whatever you want to name it)
:wq to save the file
then reboot and adjust your /etc/network/interfaces file.. then reboot again
Hope this helps someone
