I downloaded the wubi.exe file and before I install ubuntu, I want to make sure of some stuff first.
I have two hard drives in my computer C: (which have windows 7 on it) 950 GB and D: which is empty and have 500 GB in it.
I'm wondering if when I choose the installation size 30 GB in wubi (which is maximum ) it will only take 30 GB from my D drive and won't affect the rest and the C drive and whenever i uninstall wubi from control panel (if I don't like ubuntu), will I get my 30 GB back and will the D drive be back as it was?
Nofal
  • 101
As far as I can tell, yes, it will only install on the D drive, and affect only the 30gb you allocated to it. Likewise, when uninstalled, I think that it should remove the virtual disk that Wubi installs to.
If you ever want to increase the amount of space allocated to Wubi (taken from this post):
How do I resize the virtual disks?
You can use the following script to move /home to a dedicated virtual disk.
Download wubi-add-virtual-disk, open a terminal and run:
sudo sh wubi-add-virtual-disk /home 15000
Where the first argument is the directory to move to a new dedicated disk, and the second argument is the size in MB.
You should now reboot. If you are happy with the result, you can now remove /home.backup. To undo the changes remove /home, copy rename /home.backup to /home and remove the /home line in /etc/fstab.
Note that contrary to previous information, this script is not suitable for moving /usr - experienced users may be able to do this manually, at own risk, following a process similar to that outlined in the file. (Do not rename /usr until the very last moment, as rsync is installed there.)
I haven't ever used Wubi, I've just done some reading up on it, so take my answer with a grain of salt.
ananaso
  • 4,080
  • 32
  • 52
if you remove ubuntu(wubi) you will bet back your disk like it was.
