I did and upgrade from (K)ubuntu 12.04 to 12.10. It all worked well -- except for Gimp.
Gimp 2.8 works fine but loading a .NEF file (a raw file from Nikon) fails with the message
Opening '/path/to/file/DSC_2605.NEF' failed:
Procedure 'file-ufraw-load' returned no return values
I have ufraw and gimp-ufraw installed.
How do I find out what is wrong and how do I fix this?
Unapiedra
  • 167
Removing gimp-ufraw and installing gimp-dcraw helps. However, dcraw is not as nice as ufraw because it doesn't have an interactive user interface.
Unapiedra
  • 167
Use the UFRAW to process a .NEF file first, then Gimp should recognize ufraw as the sub-application to import with.
To use the UFRaw Gimp plug-in you need first to install Gimp 2.0 or higher. Gimp 2.4 is recommended. If you only plan to use UFRaw's stand-alone tool, there is no need to install Gimp, but the Gimp Tool Kit (GTK+2) is still needed. There is no need to install DCRaw itself since its code is incorporated into UFRaw.
~ http://ufraw.sourceforge.net/Install.html
Mateo
  • 8,152
Ringtail
  • 16,285
