So I'm running Kubuntu 12.10 x64:
uname -v -p  #29-Ubuntu SMP Fri Oct 19 10:26:51 UTC 2012 x86_64
and Virtual Box 4.2 installed from the VBox repositories.
Any time I try to install a 64-bit OS as a guest the install fails and crashes w/ a kernel panic on Ubuntu or bombs in Windows 7 before it will boot.
Am I missing something?
Ringtail
  • 16,285
jjesse
  • 1,115
64-bit guest should be supported, even on a 32-bit Host.
But do check the requirements and see if anything is missed out, make sure: VT-x/AMD-V is enabled in BIOS.
Also check the docs: https://www.virtualbox.org/manual/ch03.html#intro-64bitguests
If you can paste the error message (Kernel Panic/BSOD?), we can assist better;-)
Terry Wang
  • 10,185
