I've been going through docs for the past couple of hours but I haven't understood what the PPA is? I have a cross-platform Java application that I'd like to publish to the Ubuntu Software Center. My application is open-source and I'm using Github.
Apparently, publishing applications to the store isn't as simple as uploading a deb package - am I right? I need to create an account on Launchpad and put all my code there.
I don't intend to move from Git to Bzr merely for the sake of publishing to the app store but luckily, one is able to set up source-code mirroring from Github to Launchpad.
Since my application is still very premature, it'll have updates fairly often. When I build my application on my machine, do I simply go my Ubuntu App Developer page and upload the new DEB package or do they build my application from source?
What exactly is the PPA for? I don't think I'll need too many of the Launchpad features so I'd like to stick to Github if possible.
Tachyons
  • 17,455
Publishing app via ppa and submitting app to ubuntu software center are different.
Personal Package Archives (PPA) allow you to upload Ubuntu source packages to be built and published as an apt repository by Launchpad. You can find out more about PPAs and how to use them in launchpad help page.
You can publish any open source app via ppa , there is no security verification or quality check, ppa's are people who want up to date packages. So ppa's are not directly published to ubuntu software center user can additin their own risk
If you want add your app to software center You have 2 choices
  1. Via debian repository
  2. Directly to ubuntu via myapps portal
Each have it's own merits and demerits .for more details see this answer. If you want to add your software in current releases and you want to maintain it ,you should go use myapps portal
In the case of paid and non-open source software, Canonical will package and publish your app submitted as a .tar or .deb file submitted to MyApps.
In the case of Open source software at zero cost
All submissions should be through a Personal Package Archive (PPA), which you can indicate in the comment field for the reviewer when submitting your app.
It is for convenience of Application review board , They will review your app and If they found it is fit to ubuntu software center, They will push it to software center via extra.ubuntu.com repository
Keep in mind that beta versions of open source software are not allowed in ubuntu center by the ARB , You can keep bleeding edge packages in another ppa or in git itself, ie You must submit stable version to software center, and Each update in your software require review from Application review board
Some useful links
Sorry If answer confused you, please feel free to comment below
Tachyons
  • 17,455
