I'm new to linux world. Just downloaded ubuntu and installed it alongside with windows 7 . In grub when I choose ubuntu, it opens with no problem, but when I try to open windows 7, this message appears:
A Disk Read Error Occured. Press CTRL+ALT+DEL to restart.
I googled for that problem which directed me to download a boot repair tool, when I choose : advanced options / retore MBR --> apply, then restart computer , It boot to win 7 without loading the grub menu.
then I opened the live ubuntu from a USB, launched the "boot repair" again, choose : recommended repair , then restart, It returns to the first problem , grub menu appear, from which I can choose only ubuntu , but win 7 show this msg again :
I repeated more and more with the same results ...
What should I do?
I created a boot info summary using the "boot repair tool" if this can help , it's in this URL.
darroosh
  • 131
I had the same problem. It appears that either grub2, or the way Ubuntu implemented grub2, does not detect Windows partitions properly. I had a co-worker help me with this. First get grub working. Then I added the code below in /etc/grub.d/08_custom. Then update-grub. This puts Windows above Ubuntu so it will boot by default.
If you wish to boot Ubuntu by default, modify 40_custom instead. This will create a new entry for Windows along with the useless entry that was originally found. Select the custom entry to boot Windows. My new grub.cfg is at http://paste.ubuntu.com/1368590/.
Here is the contents of my 08_custom:
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
    menuentry 'Windows 7 (customized entry)' {
    insmod part_msdos
    insmod ntfs
    set root='(hd0,msdos1)'
    chainloader +1
