I want to make cpu0 offline. I have dual core laptop. I can make cpu1 offline ( using offline file ) but can't make cpu0 offline. How to do this ?
Asked
Active
Viewed 6,659 times
to enable a cpu0
you can use this
echo 1 | sudo tee /sys/devices/system/cpu/cpu0/online
and to disable
echo 0 | sudo tee /sys/devices/system/cpu/cpu0/online
Raja G
- 105,327
- 107
- 262
- 331
I've also found, certain systems cannot disable CPU0. I think usually this happens because the interrupt line is wired to CPU0, so the APIC cannot signal CPU1 on up (turning off CPU0 would cut off all interrupts and the system would lock up.)
hwertz
- 376
