If I want to install lightscribe for CD burning, how do I install it safely?
How to use simply use it?
  1. How to install?
  2. How to use it? (simple, quick way)
owl
  • 4,991
32-Bit Installation
If you have a 32-bit system, you should be good to go! Just install the debs, like so:
sudo dpkg -i lightscribe*.deb
sudo dpkg -i 4l*.deb
Now I haven’t tested this because I do not have a 32-bit system so if you have trouble, let us know in the comments! I can always cook up a VM to test this in properly.
64-Bit Installation
If you are using a 64-bit operating system, which I would wager to guess that that is true, you will have to force the software onto your system. This is never recommended, but i can’t imagine that the impact of the software is significant enough to cause any damage to your install. The Ubuntu help page however, gives the following warning;
So, that said, here are the commands!
sudo dpkg --install --force architecture lightscribe*.deb
sudo dpkg --install --force-architecture 4l*.deb
Now, let’s run it.
If you want to create a disc with an image covering the surface:
sudo 4L-gui
If all you need to do it print a little text on a disc:
/opt/lightscribeApplications/SimpleLabeler/SimpleLabeler
owl
  • 4,991
The following method was succesfully tested on 15.04 64bit:
  1. Install the following dependencies:
    sudo apt-get install gdebi libsm6:i386
  2. Download the Lightscribe deb packages from the Pawtec website:
    wget http://www.pawtec.com/lightscribe_files/Linux/LSS/lightscribe-1.18.27.10-linux-2.6-intel.deb
    wget http://www.pawtec.com/lightscribe_files/Linux/LSL/lightscribeApplications-1.18.15.1-linux-2.6-intel.deb
  3. Download the multi-arch version of LaCie 4L Labeler utility created by Davide Depau.
    wget http://download.tuxfamily.org/davidedduos/misc/4l_1.0-1_i386.deb
  4. Install the Lightscribe deb packages:
  5. Install the LaCie 4L Labeler utility and its dependencies with:
    sudo gdebi 4l_1.0-1_i386.deb
Now to create labels run:
To burn your disc type:
4L-gui
Source: https://help.ubuntu.com/community/LightScribe
